RCU Forums - View Single Post - IR system update & other run stuff
Old 04-27-2007 | 07:57 AM
YHR's Avatar
YHR
Default RE: IR system update & other run stuff
ORIGINAL: ksoc
Did you try any tinted plex or louvers to shield the IR Rx? Would be cool to see some shots. If you look at the MOTOR POOL on our site, you can see the 'Home Made' IR system that Merle built for his HL Tiger. He started with the TANKHOBBY battle circuit. He has also crammed it into a 21st Century PAKWAGEN.
http://web.mac.com/ksoc/iWeb/S.C.A.T...or%20Pool.html
Kevin O
<S.C.A.T.>
Yes I will try some shielding today. I made up parabolic mirror hoods to go over a couple. I'll try using them to see if it improves the sensor.
