RE: Problems
I'm with Grits - you're running too lean to begin with. An R/C will lean out a bit as the tank empties. And if you are already too lean this will exacerbate the situation. Try pulling the glow plug and checking out the coil. If the coil is slightly distorted (shape wise) then that is definately the problem.
