RCU Forums - View Single Post - Cutting grooves for hinges
Old 04-27-2007 | 11:53 AM
jquid's Avatar
jquid
Default RE: Cutting grooves for hinges
For future use, if you are using "hinged" hinges, cut a little piece out on both sides around the hinge itself. This will set the hinge in closer and eliminate the large gap you have. You should really seal the gap you have, otherwise it may feel mushy.
