RE: G23 UNRELIABLE. HELP NEEDED!
Check that the pulse hole in the carb base is aligned with the pulse hole in the base gasket. Then make sure that both of those are aligned with the the actual pulse opening . Then check that the throttle is moving the correct direction for the intended results.
