RE: Plans
I will send you a set by pm let me know if you get them. Hey you could probably tape them together and take them and get them blown up at kinko's. Just remember if you build it the formers for the top that have the radius need to be sanded to take some of the curvature out of the deck. I had a little problem when I built mine with the radious so I hand scribed the two formers with a pencil and took a flat bar sander and slowly sanded them till I liked how the deck looked. If you dont sand them what will happen is when you cut the deck and I cut mine 1/4 in oversize is with the severe radious it will tend to pull the corners at the transom in making it come up short to cover the edges at the sides even with the deck being cut big.
