Webra 15cc P5/Speed-P5/ Performance
Hi Fellows,
My search over RCU on RPM-readings of WEBRA-15cc did not produce much.
I am especially interested in the latest models of Speed-P5 and plain-P5.
Could you please post your experience, mentioning at least the most
important of the things in the list below:
1) Propeller: Maker, Type, Material, Diameter, Pitch, ...
2) Pipe: Tuned, Wide-barrel, Pits, Standard, or Open exhaust, ...
3) Fueling: Pumping by Perry-pump, Direct Pressure from Crank-case,
Pressure from the Exhaust barrel, ... any Special Regulator on Carb ...
4) Fuel: Oil% and type(s), Blend-proportion%, Nitro%, ...
5) Environment: Temperature, Altitude/AthmPressure, ...
6) How New/Old/Used the Engine is.
7) Did you "tune/improve" the engine and how ?
Nick
