RCU Forums - View Single Post - G23 UNRELIABLE. HELP NEEDED!
Old 04-28-2007 | 10:44 PM
zeng62's Avatar
zeng62
Default RE: G23 UNRELIABLE. HELP NEEDED!
Under the plate with one screw there is a micro screen that gets dirty or gummed up with dryed gasoline.
This is a common problem with any gas carb. I use a needle or small pin to remove the screen which is about 6mm or a 1/4 inch in dia.
I then hold the screen with forceps and clean it with carb cleaner.
Also check the carb gasket and make sure the pulse hole is not covered.
GSM
