RCU Forums - View Single Post - BlackJack dialed in
Old 04-29-2007 | 05:15 PM
kevinle
Default RE: BlackJack dialed in
that exactly i expected to hear from SouthJerseyFe, explaning to me diff between sv motor and XL or something, my point is not about waising money or time, not even close, and i dont think my question is obvious at all, just because he is so sensitive person i guess, hopefully you dont have that hight blood pressure problem SouthJerseyFe
ORIGINAL: ryan_t888
ORIGINAL: kevinle
Hi SouthJerseyFe, maybe im missing something here, but with 14cells your boat running 31 mph, so its run slower than a stock SV27??? your boat got more torque motor, more cells and also your hull is not much heavier than a sv hull, please explan that for me if you can.
A 12XL or 11XL is around 1400RPM/V. On 14 cells that will be around 19600RPM. A SV motor is 1800RPM/V giving about 21 000RPM. Both these motors produce nearly the same horsepower on 14 cells vs 12 cells of the SV but the SV outputs more RPM.
if you hang me a more powerfull motor, beter esc and more cells # than another guy or BIG TEAM i dont care, i can guarantee you 100% then my boat will go FASTER than them, at least on the straight line, if we use same size of hull, and its not hard at all, AND you dont need that 15 or 20 years of experience to do that, everyone can do that.
What are you trying to say? What you said is VERY obvious!
Ryan
