Make sure you have fuel to the carb. You can pull the line off the muffler and give it a couple of quick puffs. Make sure your ignitor is charged. Pull the plug and connect the ignitor. You should have a strong glow. Good spark and fuel and you should fire. you could also trim the throttle servo up ( open at the carb ) just a bit when starting.
ORIGINAL: chris246810
hello dam these engings are real hard to start or the glow plug isn't charged i just tried to start my genisis and nothing not a dame thing. i dont wanna keep trying it cause i dont want to break the recoil spring. i will leave the fuel in the gas tank and all primed for tomorrow when i get home after work. i day shoulond't be so bad. i even tried holing the throttle down a little bit.
