RCU Forums - View Single Post - brushless setting up.
Old 04-30-2007 | 08:00 AM
jdoug
Default RE: brushless setting up.
alex - Did you get connectors put on the controller and motor? If so, just connect the 3 wires from the controller to the 3 wires on the motor and check rotation when you blip the throttle. If it spins backwards, just swap any 2 wires and you'll be good to go!
