Go Back  RCU Forums > RC Boats > Speed - Electric
 brushless setting up. >
Speed - Electric For all your electric boating needs.
Old 04-30-2007 | 07:55 AM
Alex73's Avatar
Default brushless setting up.
i have this [link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/comersus_viewItem.asp?idProduct=4316]esc[/link] and it has 3 red wires, how do you connect it up to the motor? the motor is a Feigao.
thanks for any help
Old 04-30-2007 | 08:00 AM
Default RE: brushless setting up.
alex - Did you get connectors put on the controller and motor? If so, just connect the 3 wires from the controller to the 3 wires on the motor and check rotation when you blip the throttle. If it spins backwards, just swap any 2 wires and you'll be good to go!
Old 04-30-2007 | 08:11 AM
Alex73's Avatar
i have some connectors i can use, which way should it spin? if your looking at the front plate
Old 04-30-2007 | 08:19 AM
It should spin in a way that moves your boat forward. Just being a smart ***** Use the gold plated connectors. I think I have some that are 3.5 mm (bullet) that I'm going to use on mine.
Just a note: if you haven't got a prop yet...the prop you use will spin counter-clockwise when looking at the transom. The same goes for the motor as it is direct drive.
Old 04-30-2007 | 08:48 AM
the esc middle wire and motor middle wire is always the same, 2 other side wires are + and -, its wont hurt anything if you mix up them, just changing your motor direction, make sure dont mix up the middle wires.
ORIGINAL: alextitchmarsh
thanks for any help
Old 04-30-2007 | 09:01 AM
BB Modss's Avatar
All 3 wires can be connected any way you want, There is no + or - wires coming out of the esc,its AC current pulses.
Old 04-30-2007 | 09:30 AM
BB Modss is right. Hook the wires up any way you want. If it doesn't spin the right direction...swap ANY 2 wires and it will reverse the rotation.
Old 04-30-2007 | 10:07 PM
BB Modss's Avatar
Just to clear thing's up,if the motor isent turning in the direction you want,swap any 2 of the 3 wires going to the motor,sounds silly but i get guys in the shop i work at at least once a month telling me they need a new esc because they were told to swap any 2 wires,and they swapped the power wires coming from the battery....don't laugh..it happens to us all some times.
