RCU Forums - View Single Post - Roybi Ignition Clearance
Old 04-30-2007 | 02:42 PM
ROOSTERLEW
Default RE: Roybi Ignition Clearance
what did you use to clean it? Did you take carb apart or blow in it with compressed air? If it has happened to two engines then it is something you're doing(not being rude, just logic dude) You need to step back through the process and see where you goofed. I can be very helpful..I goof alot!
