RE: Glitches !!
I am also a little new to Gas but had the same problem. Here are two things that may be the cause of your probelm:
1. The receiver battery may be to close to the Ignition module or Ignition battery.
2. You may want to invest in a PCM receiver to avoid the noise interference from the engine.
Hope this helps.
