RE: Lift Meister
Looing good Bob! I like your tail wheel hook up---should work great. I have mine rigged for 3 jumpers and have loaded 2 mikes and 1 charly but didn't time the climbout to drop alt. Probably about the same as yours as I have a tuned pipe on mine for more rpm and to keep the exhaust off the jumper hanging in the center between the gear. Gets about 8000rpm with a 19x8 APC W prop. The climbout is much better with 3 Charlys because drag and weight is less than the Mikes. We should have a good comparison when we get to Somerset.
Jim
