RE: PROBLEMS with my firebird freedom
SONYMASTER20 I need a favor from you. I just bought a used Firebird Freedom and everything seems to work OK. My only problem is that the plane checks out tail heavy with the CG 1 1/2" from the trailing edge of the wing (battery installed). Could you take the time to check where the CG is on your FF (battery installed) and get back to me?? Thanks
