RE: Composite-ARF Integral, kinda build thread
At this point so far the only thing I did for the rudder horn was drill the hole and add some thin CA to harden the block in the rudder. So far it is holding okay. I did not use the supplied control horn because I thought the removal of all that material from the rudder would weaken it. I used an IMP rudder control horn from Central Hobbies.
The engine I used (OS1.40 RX) required a custom rise header. The mount used was a Dave Brown Pipe mount mounted towards the rear of the pipe tunnel.
Carl
