RCU Forums - View Single Post - adding a smoke system
Old 05-02-2007 | 02:53 PM
rzarikian
Default RE: adding a smoke system
try to lacate the nipple at a low pressure area (remember: at greater speed less pressure.) vernulli theory. don't install it in the wide part of the muffler this will make it easier for the pump to deliver the oil. and try ti put it the closer to the cilinder as possible. here is a link to get you started. http://www.greathobbies.com/technical/tech_smoke_1.php
