RE: adding a smoke system
I probaly could have gotten away without the pre-heat, but then hotter it is then more it smokes. Also, it helps smoking up a storm when you are running low throttle. This model was very overpowered and I liked using smoke while hovering so it helped at lower throttle settings.
