Covering your Zagi
I agree, the tape will do just fine. I put it on mine and ran it into a few things; including straight down into the sidewalk, without a problem.
If you do want to cover it I'd recommend Econokote not Monokote. It needs less heat to stick so you are less likely to melt the foam.
