Covering your Zagi
Covering your Zagi
What type of experience have you had covering your Zagi's? I will be building one in the next week, and wanted to know if covering with Tape (as supplied in the Kit) or covering with Monokote was better? (by the way better means weight vs strength).
Thanks for your input.
-Jon
-Jon
Covering your Zagi
I have heard of some covering with Monokote, but I don't think it'll give you better performance. Also, one has to be careful when taking the iron to the foam. It can be done, just gotta keep the iron moving.
The tape shipped with the kit is pretty light and I don't think it is meant to provide strength to the airframe. www.fast-pack.com has some pretty good prices and colors to get creative with tape.
TX
Covering your Zagi
My zagi is covered in tape. Before taping it, I spraied it with 3m sticky spray. It makes it stick better. Go with tape- It is easier to repair.
Richard
Richard
My Feedback: (9)
Covering your Zagi
I agree, the tape will do just fine. I put it on mine and ran it into a few things; including straight down into the sidewalk, without a problem.
If you do want to cover it I'd recommend Econokote not Monokote. It needs less heat to stick so you are less likely to melt the foam.
Covering your Zagi
I used standard Ultracote on my Zagi. It worked great. Looks much better IMHO than the tape.
I do agree though, do not use standard Monokote on a Zagi. The foam cores won't like it much.
