Emaxxxxxxxx Upgrade
I really want to upgrade my EMAXX to the best motor possible. (of course possible means not too expensive.)
So I'm planning to get a super rooster ESC and a set of 3000mAh 9.6volt 8 cell battery from all batteries outlet (are they really good batteries?).
now.. what motor will allow me to run 9.6 volts?
Will the super rooster work with 2 8 cell batteries?? that's 16 cells... i don't know if the specs limit is total cells.. i think it's 10 cell limit.. if not, what other reversible ESC will I be able to use??
OR should I just run the stock motor with a 7 cell battery??
What gears should i be running for the best balance?
