RCU Forums - View Single Post - LT-40 Trainer
Thread: LT-40 Trainer
Old 02-26-2003 | 03:57 PM
  #64
nukes
Default LT-40 Trainer
COROPLAST™
COROPLAST™ is a high-quality polypropylene twinwall profile sheet formulated specifically for use in the screen printing, display and packaging markets.
COROPLAST™ uses a copolymer resin in order to increase impact and low temperature performance. Copolymer resins are also used because they retain the ability to be flexed an unlimited number of times without breaking. We call this unique ability "a living hinge."
Chemically, the sheet is inert, with a NIL pH factor. At regular temperatures most oils, solvents and water have no effect, allowing it to perform under adverse weather conditions or as a product component exposed to harsh chemicals.
All COROPLAST™ twinwall profile sheets can be modified with additives, which are melt-blended into the sheet to meet the specific needs of the customer. Needs that require additives include: ultra violet protection, anti-static, flame ratardancy, and color.
COROPLAST™ products are offered in a wide range of standard, opaque and translucent colors.
For the Graphics Arts Fields COROPLAST™ makes the industry leading corrugated sheet plastic, COROPLAST™
COROPLAST™ is the material of choice for today's screen printing industry. COROPLAST™ is ideal for indoor and outdoor applications. It is tougher than corrugated fiberboard and lighter than extruded plastic sheet.
It is waterproof, stain-resistant. Graphic artists have been using COROPLAST™ successfully for years with some of the uses being: Retail Signs, Real Estate Signs, Political Signs, P.O.P.Displays, Bus and Truck Signage, Election Signs, Yard Signs, Agricultural Signage, Special Event Advertising and Trade Displays
