RE: Little help, please...
Exaclty what I was referring to. But it's not a problem, that's normal, the interference caused by the pliers contact with the engine will leak through the channels on all but the most expensive radio systems.
EDIT: Sounds like you solved the problems with the crystal. Well done.
