RCU Forums - View Single Post - Blade CX2 - Help me!!!!!!!!
Old 05-06-2007 | 10:36 AM
p01rogue's Avatar
p01rogue
Default RE: Blade CX2 - Help me!!!!!!!!
Just curious if any of you with CX2's noticed that the reciever unit just kind of dangles and isn't secure. I just got mine brand new and noticed this.
Trinity servo tape, clean both sufaces first with rubbing alcohol or bearing claener or brake cleaner.
Also, I chipped one of the lower blades. Now the nose tends to slowly turn right in tiny spurts while hovering. I noticed that the nose will turn extremely fast to the right but when I turn it left it will go WAY slower. Will replacing the chipped blade correct this problem?
Change damaged blade, adjust proportional to your liking, mine will turn right and left at same rate.
Another thing I noticed is the part with velcro in the heli where the battery is supposed to press up against is way too far up front. In order to stick the battery that far up there and press up against the velcro, I would have to put the battery in wire side first which would smash the wires in there and be WAY too much of a pain in the you know what. So, I've just been flying it without the battery being velcro'd down. Do you guys do this too?
Velcro on side of batt without wires, insert with wires out rear of heli.
Also wondering what mods actually work well. I want to be able to fly mine outside with better performance than stock (in calm conditions of course).
