RE: 2m Pattern Help
I know that smaller pattern planes aren't particularly BAD, I just don't see them as being quite as stable. Also, does the 120AX really have enough Power-to-weight to do a good job in the VenusII? If it is used, however, wouldn't it require a pump to get fuel from the midship tank? I'll look into the VenusII/120AX combo, looks pretty good. I know the Venus's won't do any 3D in the hands of anyone less than perfect, but I know there must be some pattern ships that do okay 3D. Does anyone have any experience 3D-ing the Obsession 3D?
Now, let's say I'm stubborn (anyone who has met me will agree that stubborn is an understatement) and am stuck on the DA-50. My list includes: 2 Futaba S3004 (throttle/choke), 5 JR ST126MG (everything else), Futaba R138 PCM 8-channel receiver, the DA with the DA in-cowl muffler, two Hydrimax 6.0V 4200mAh NiMH Sub-C Flat batteries, 1 Smartfly Turbo-Reg.
Okay, that gives battery redundancy. What do you think of the set-up so far? What ignition battery should I use? Are there any accessories that aren't completely necessary but a definite plus to have?
One last question for this post, are there any ARF pattern ships around 12-14 pounds (75-80, i'm guessing) at or under $450?
