RE: 1/8 Scale Armor
Trev:
It's great to see your KT build is underway. Looks like you're having great fun with it.
I'd like to know what you think about the new suspension once it's in working order. I may ask Mike D. if its possible to retro fit my older KT with the newer suspension.
While you're in this stage of building, you might want to look at water tight seals where the road wheel axles meet the hull. That way, you can ford streams without worrying about taking on water.
BTW, I repaired my gun barrel with no problem at all -- very easy with what Mike had sent.
Cheers...
