RE: RUDDER EFFECTIVENESS
May i sugjest you install two fins on the bottom of the fuselage, they will help keep the nose of your plane heading strait and will realy speed up roll/spin recovery
Also, when you say "high AOA" do you mean well past stall angle? if the main wing has not stalled yet the airflow will "stick" to the top of the wing and flow past the rudder without a problem
