RCU Forums - View Single Post - Goldberg Extra 300
Old 05-10-2007 | 03:05 AM
  #134
Dauntae
Default RE: Goldberg Extra 300
ORIGINAL: Mark786
I am still undicided about mounting the elevator servo (s) in the tail. I don't like the setup on the plans and I may need the weight in the tail. Any suggestions? I liked the picture of two servos on either side of the Pull/Pull and may use something like that. I will completely assemble the plane before covering and if the weight is needed I will install in the tail although I don't like the looks. Thanks for the suggestion on the larger tank as all I could find was a long tank at 12 oz.
Putting the servos midway down the tail worked well, I think my post was on page 3 about it. To get to the servos I put the punched out ply back with tabs in the corners to and it definately helped with the CG with a Saito 150 on the nose.
Dauntae
ID:	681303   Click image for larger version
