You'd have to sheet the entire fuse before you can glass it.
It is possible to cover with Koverall or dacron, seal the fabric with dope, then coat the fabric with epoxy, and stick the fiber glass down over the fabric covering. Makes a hard shell, however it can have problems with heat expansion, contraction, and can cause a wing to temporarily warp. I only recommend it over say fuse cut outs.
