RCU Forums - View Single Post - Construction and Build Log - Griffin Trainer Kit Build
Old 05-10-2007 | 06:50 PM
  #41
e-flight22's Avatar
e-flight22
Default RE: Construction and Build Log - Griffin Trainer Kit Build
Specs of Griffin:
wingspan: 60"
fuselage length: will have to check
wing loading: have to work out still, need to find that equation thing to find it
weight: its sitting at roughly 4.00lbs without covering, nose cone, and prop. so i think when all done it should be roughly 4.50lbs
power setup: Astro 05 brushless geared motor, 60 amp speed control (went overboard here, it was an extra one i had )
battery: 3s1p 5000mah li-poly pack
radio gear: electron 6 reciever, and 4 hitec HS-85BB servos. two for the wing and one for rudder and elevator.
Props: thinking a 12x6 or something around there, the 05 has a max amps of 40-45, so im planning on propin it so it pulls less than 40amps. will have to do some testing to find out the best setup.
ORIGINAL: Gary L.
David, it looks great, I like the red, white, and blue. [sm=thumbup.gif]
What's the spec's on it ??
