RE: Throttle push rod?
I just switch over to 4 strokes and had the hardest time getting the throttle set up. I use a flexible braided cable and sometimes the Dubro 4s throttle linkage. Makes a very smooth setup.
The loop way RCKen described will work fine . I use large fiberglass mounts that have a big webbing on them and have trouble getting the wire to clear.
