ORIGINAL: BirdofpraY
Tam, Mauri, do you think the DS3421 on rudder will be sufficient with nylon gears; thats my only worry about that servo. When I owned a Skymaster Hawk I used the nylon servo and it shreaded the gears from either flutter or break of former. The DS168 has metal gears but alittle less torque, and have heard them to be used in the F-18E's. I think I will do 2 DS8611 on the flaps since the price are the same as the 8411's. Thanks Tam, and Marui for the info...
Hello, the DS-3421 has metal gears... the DS-3421-SA is the one with the nylon gears and it is reported on the internet to be a little delicate, thats why the normal DS-3421 is preferable.
I already had the DS-8411, you'll be ok with the 8611!
Mauri, Italy
