SuperCap building problem....Help?
I'm having trouble putting this thing together. I only have the first part of the main body together (I think I have it right) now I'm trying to put together the horizontal part of the main body. I guess my first problem is I cant figure out what pieces of carbon your talking about....Im guessing the flat pieces are what I need to cut to size. It states there are 2 short cuts in the 3mm fuse core at the nose of the plane. If I am correct each of thoes cuts is about 8 1/2" long with another 1 1/2" to the tip of the plane for a total of 10" from the back of the cut to the tip of the plane. I can't see that well from the pic but it looks like I need to place a piece of the thin carbon from the back of that cut to the front of the nose. If this is correct I should need to cut 2 - 10" pieces of carbon one for each cut section. In the directions it says I need to cut 2 - 4.6" pieces of carbon for thoes cuts. that would leave 5 1/2 " of space with no carbon. Are the directions correct? If they are i appologize this is my first attempt at building one of these and I'm just not getting it then.
Please help I have everything laid out all over the table and my wifes getting pissed....just kidding shes just a little upset .
