RE: needle help!
Unscrew the needle housing and theck the threads on that and the carb.
If that seems ok then unscrew the needle from the brass housing completely, re-attach the housing to the carb (make sure it's quite tight without stripping the threads) and then carefully replace the needle and set it to factory settings.
