needle help!
Old 05-12-2007 | 11:36 AM
sunco1's Avatar
Default needle help!
well when i was resetting my car back to factory settings on the high speed needle i turned it in a little far and i started to unscrew the whole high speed needle( like that thing the connects to the fuel was coming out, and the 2 spacers) now when i go to put it back in, it only goes till the first spacer touches the carb and it just spins....?!?
help please
thanks
Old 05-12-2007 | 12:26 PM
snowbl!nd's Avatar
Default RE: needle help!
Have you stripped the threads on the needle assembly? Not the needle itself but the housing where it attaches to the carb body...
Old 05-12-2007 | 12:32 PM
sunco1's Avatar
idk how can i check?
Old 05-12-2007 | 12:49 PM
snowbl!nd's Avatar
Unscrew the needle housing and theck the threads on that and the carb.
If that seems ok then unscrew the needle from the brass housing completely, re-attach the housing to the carb (make sure it's quite tight without stripping the threads) and then carefully replace the needle and set it to factory settings.
