Problems programming XPS Extremelink Module?
Is anyone else having problems setting the power output on the Transmitter module? I have the unit that fits my Futaba 8UA. This thing is making me crazy!! After following the instructions " With the STATUS LED solid red, press and hold the PROG button until the STATUS LED turns off. The STATUS LED will now slowly flash green the number of times equal to the current power setting". Mine just starts flashing rapidly and continually! I turned the power off and tried to bind - no luck! Any clue as to what is wrong? If, by chance, I messed up the programming, how do I reset it to factory default? - or should I return it to XPS?
HELP!
Phil
