RCU Forums - View Single Post - Problems programming XPS Extremelink Module?
Old 05-12-2007 | 07:57 PM
chrisF test pilot
Default RE: Problems programming XPS Extremelink Module?
What procedure are you using to bind? You should start by turning the Tx on, when the LED starts blinking red hold the prog button until it goes off then green. When you release it should start blinking orange. Now power on the Rx and same thing. Once LED starts blinking red hold the prog button until it goes off then green. Release and mine blinked a few times then went green, which indicates a good bind. Now power off both, then power back on and you should have control.
