RCU Forums - View Single Post - Ball link vs clevis? CG Ultimate...
Old 02-26-2003 | 04:01 PM
barryb-RCU
Default Ball link vs clevis? CG Ultimate...
You'll be fine with standard clevises. Ball links really add to the expense. With them, you need metal servo arms to handle the twisting action the offset ball links put on the arms.
The only problem with clevises in that size plane is that eventually you'll wear the holes in the servo arms and need to replace the arms. Even that'll take 70 or more flights.
