RCU Forums - View Single Post - Need help with wing set for alpha trainer
Old 05-14-2007 | 09:45 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Need help with wing set for alpha trainer
How are the wings joined on this plane? Do you epoxy them or are the held in place with screws. If you don't have the original wing permenantly joined I would just use the good half from the first wing with the other half from the replacement wing. It looks like the hole is missing on the same half that is good from your old wing. Just mix and match the wing halves and you should be ok.
Ken
