RE: Mini IFO set up help
I am having a problem setting up the Mini IFO on my Spektrum DX7...I have the ailerons working correctly, but the elevator outputs are reversed (up is up on the stick, down is down onthe stick) Reversing the servos on the radio does not fix the problem, and have it setup as a delta wing. I am using 2 servos ....one plugged into the elevator and one in the aileron port in the reciever.
I know I am missing something stupid, please help, with what the correct DX7 setup should be to make it work properly
