RCU Forums - View Single Post - Seal Balsa before applying epoxy ?
Old 02-26-2003 | 07:11 PM
Ben Diss
My Feedback: (23)
Default Seal Balsa before applying epoxy ?
The purpose is to prevent the adhesive from soaking into the wood. The goal is to save weight by using less epoxy.
The real question is: Do you want the epoxy to soak into the balsa (strenght vs. weight) and is the material being used to seal the balsa adding as much weight as would be saved in epoxy?
-Ben
