ORIGINAL: bonanzadrv
Just Setting up my plane with a Da-50 and electronic ignition. I always try to keep radio gear as far away from the ignition stuff as possible. In this new setup my receiver is only about 8.5 inches away from the Ch ignition module. Is this far enough??? What about distance from the ignition switch (using a heavy duty Jr switch and it is only 6 inches from receiver.
I will of course do a range check with and with out engine running. Just trying to see if I am going to have problems or not?
Bill
It seems too close at first glance but each install is a bit different. If I got a good range check with a PPM receiver I wouldn't be afraid to fly it.
