RCU Forums - View Single Post - Engine at 45deg angle
Old 05-15-2007 | 04:05 PM
opjose's Avatar
opjose
Default RE: Engine at 45deg angle
Over the past year I've broken in 8-9 new engines, all inverted.
Other than the noted siphoning issues, and slightly more intolerant needle settings, they run w/o problems.
This includes OS, Evolution, Supertiger, Magnum GMS & Tower Hobbies engines ranging from 2 stroke .46's through BGX-1's and four stroke 1.80's.
None run with glow assist, though I had purchased an on board ignitor to handle my Evolution 1.00NX.
My Evolution 1.00NX was the most intolerant of the inverted position, but I'm glad I mounted it that way. Mounting it inverted and my frustrations with it this way resulted in my eventual replacement of the carb, which cured all of the problems I had with the engine.
It ran fine inverted once I resolved the problem it really had.. I never did install the on board ignitor.
Better that I find this out on the ground, rather than in the air with the plane inverted or on it's side.
