RCU Forums - View Single Post - Tissue Covering
Old 05-16-2007 | 08:26 AM
RITTMEISTER's Avatar
RITTMEISTER
Default RE: Tissue issues
Thanks for the info!
I applied elmers glue on all the edges and put the tissue on Then I moistened the tissue with my fingertips and formed all the edges. Then lightly sprayed water on them. To keep from warping I secured to my building board. After all shrinking I sprayed Krylon Clear coat .A couple of coats. Is this going to work???? My son picked up one plane from the flying field after maiden flight so excited his fingers went right through the fuselage covering.[&o]. will nitrate dope make the tissue stronger than applying Krylon spray??
RITT
