RCU Forums - View Single Post - roto starter
Thread: roto starter
Old 05-16-2007 | 08:26 PM
chris246810
Default RE: roto starter
hello.. its a good day... i got my new roto starter yesterday from cen when i got home from work. i installed the roto starter and put everthing back together. i then proceeded to get everthing ready to start my gst up. i was antisapating problems but i guess luck or something was on my side cause i filled up the tank primed it and then hit it up with the roto starter and it started i was so happpy it felt good but after that i was better cause at least it started for a second or so. then i adjusted my thorttle trim to 0 i think it was to far in the closed postion and then it ideled good wihtout stalling. i then let it run thorugh the second tank of gass while i ate dinner i let it cool down and i started on the thrid tank of gas. the engine started right up for the thrid time it was nice. to bad it rained today when it got home from work but tomorrow i will start to break in the engine while i drive it slowly around. also i was told by my LHS that i should use a receiver pack rather then batteries. he said the pack wold be stronger then regular batteries. i can see when i turn the gst the stearing dont really turn that much is it because its idel? also when it was running i noticed the trasmission gears moving is that normal and when it gets low on gas it would jump from netrual to full throtle is that normal also? thanks for your help guys.
