ORIGINAL: john0087
No,
You do not need to disassemble the gearbox to adjust the diff. You will have to remove the camber tie rod, to remove the cva. You can then access the diff adjusmtnet. I only adjust the diff when it feels to be getting to lose.
good luck
JOhn
Thanks, just what I wanted to find. Manual doesn't mention anything about checking the diff or accessing to it!
Cheers
