Diff adjust for GT2
No and you can get the instructions at http://www.teamassociated.com/ look it up in the manuel, its pretty simple [&o]
VA
In the manual is says "Its not meant to be a tuning option" but I read in the other forums that you can set your diff depending on track surface.
Does Lock or fully tight diff will cause you to strip gears?
CA
The dif can be used as a tuning option, but it is not recomened. Its sole purpose is to allow the outside wheel to turn faster than the inside wheel during cornering.
You diff should not have any slip in it at all. I usually run my diff on the tight side. Tighten the adjustment screw till the diff spring is compressed then losen 1/8-1/4 of a turn. An excessively lose diff will do nothing for performance and just wear out parts sooner. Don't confuse a smooth diff and a loose diff. If built propery, your diff action can be very smooth with the proper "tightness"
If you are running an a low traction surface, it is better to losen the slipper. That is what it is there for.
Good luck.
John
Good luck.
John
CA
On overly tight diff by itself will not strip gears, but combined with an improperly set slipper (too tight) and hard landings with the throttlle pinned could strip gears.
John
ORIGINAL: rclynx
Correct me if I'm wrong, isn't it possible to adjust the diff using the rear wheels while holding the spur gear? I read GT2 RTR review, a reviewer found the diff was a bit loose after few tanks so he re-tightened it!
CA
ORIGINAL: barnettgs
Ok, this is the last question hopefully!
Do I have to disassemble gearbox to adjust the diff?
You do not need to disassemble the gearbox to adjust the diff. You will have to remove the camber tie rod, to remove the cva. You can then access the diff adjusmtnet. I only adjust the diff when it feels to be getting to lose.
good luck
JOhn
ORIGINAL: john0087
No,
good luck
JOhn
No,
good luck
JOhn
Cheers
take the rear dogbone out, and stick a screw driver in the little hole in the gear box (the thing the dogbone sticks into) (forgot which side it's on), tighten the screw all the way down then back off about 1/3 or so turns...in answer to your question no you don't need to disassemble the gearbox, and yes it is a very helpful tuning option...also make sure you have some good grease, or lubricant so your diff is smooth...
too tight- wheelies, bad cornering, will spin out easier
too loose- slower through turns but more forgiving b/c you won't spin out
One of my xtreme rc magazine articles had everytihng about the diff in it...check out rc411.com
