The stock clips seemed a little weak to me so I swapped them for flat e-style from
www.mcmaster.com part # 98543A101 - A bag of 100 is $3.03. I also lubed the pins as stated in the manual.
My Lightning is set-up on the JR 10x under code 22 - wing type - quad flaps with dual elev. My rudder and steering are thru a matchbox. I found it keeps things simple this way, but uses all 10 channels.
Rcpete, are you going to Winamac in June?
...Scott
