RE: PVC Pipe Problem
tip: easy way to get the tyres onto the rims.
buy weathering tape. its a tape with one side which is sticky and the other is just foam. you use it to put on the window frame so wind doesnt creep in.
pur this, i bit streched onto the rim and slide the tyre over, its a tight fit, but doesnt come off while driving and easy to remove once tyre is worn thin and heated.
