RCU Forums - View Single Post - engine box sides for 2.5 degrees thrust
Old 02-27-2003 | 06:33 PM
Ron Eisner
Default Mike... make your life EZ:
Over the years of building for others, I have learned what motor you build for might not be what the next owner might want...
Build you firewall about 3/4" shorter then called for in the plans with NO offset... then use spacers (offset spacers available from Roger at Aerografixs at 613-933-7296, www.aerografixs.com) to set your motor.
I sell alot of airplanes less motors... this is a great "universal" front end set-up.
Ron
R and D Aero
